-   USA (#/f/forumdisplay.php?f=25)
-   -   S14 Silvia brakes. (#/f/showthread.php?t=640965)
RyanG012 01-21-2017 07:28 AM
S14 Silvia brakes.
Can I use 240sx rotors?
RyanG012 01-21-2017 12:14 PM
Also what pads fit? If any in USDM
lunchmeat 01-21-2017 01:54 PM
What are you even asking? Can 240 brakes fit a 240?
RyanG012 01-21-2017 01:59 PM
No km asking if I need rotors and pads for my JDM s14 SILVIA. but I am in the states can I order standard usdm s14 240sx pads and rotors.
I have tried searching with no luck.
lunchmeat 01-21-2017 02:12 PM
I think the jdm fronts are 300zx brakes and rotors, and the rears are the same.
But I'm no brakeologists.
RyanG012 01-21-2017 02:23 PM
Pads may be. The rotors look thinner in the Silvia or i may be crazy who knows
lunchmeat 01-21-2017 02:29 PM
Any part numbers on the calipers? It's been years since I've messed with s14 brakes.
RyanG012 01-21-2017 02:30 PM
I'll look here shortly. Thanks for the help🤜🏼
FRpilot 01-02-2018 04:33 PM
S14 JDM Silvia front brake calipers should be the same as z32 4 pot iron calipers (30mm). You need to use z32 30mm pads to fit.
S14 USDM 240sx front brakes are not the same as S14 JDM front brakes. They are a floating (sliding) caliper.
s14 JDM & USDM rear brakes are the same.
All S14 brakes are interchangeable with all S14 chasis. (JDM, USDM, EDM, etc.)
