No holes in firewall for clutch slave cylinder
so i was looking on my firewall today in search of three hole for the clutch slave cylinder and the only hole was the one for the hood latch cable. i have a 91 base model hatch auto. did nissan not make these interchangeable without drilling.
wait... what? The clutch slave bolts onto the trans
(maybe he means the master cylinder)
Slave bolts to side of the tranny to operate the clutch fork. I think you're meaning the clutch master cylinder which bolts to the firewall beside the brake booster. If you can't see where it goes there, stick your head under the dash, and you'll see where it should be.
No they did not. With the Auto you will have to drill/hole saw the holes in the firewall to mount the master cylinder. The location for the holes are stamped in the firewall and its pretty simple to do.
^^ yep. its ez if ur drill is short. mine was big so it was kinda pita but i got it done. theres indentations so just tap a hole right in the center and drill away
yea guys i was talking about the master cylinder. but i also dont see the indentations i ll post pics for you.
Or you can convert to a bottom mount Wilwood master cylinder :naughty: |
The stamped part is INSIDE the car. Get up under the dash and pull the sound deadening carpet shit back and you will see where to drill.
| All times are GMT -6. The time now is 11:23 PM. |
