clutch pedal return spring install tips?
i'm trying to install the return spring in my clutch pedal and i'm just having a shitty time trying to compress the spring.
Anyone have any tips for installing it? I got the whole pedal assembly out already |
Quick question where did you buy the spring?
perfect thank you
I did this with my dash out and pedal still installed, so I had easier accessibility. Pretty much I slid one end into the hole and used needlenose pliers to try to force the other end into the other hole. I had to play around with it for a little bit but I eventually got it in, dont be afraid to use some force.
I would also recommend to get little bushings to prevent the pedal from squeaking; again this is from personal experience. I got my spring from FRSport. |
| All times are GMT -6. The time now is 02:28 PM. |
