White bunny special (240mm Clutch How-To)
I would like to know what this consists of. i have searched a couple places and know to use a 280zx clutch but what kind of flywheel do you use??? also, what year flywheel and what year clutch??? thanks |
go on FA and ask him directly.
1993 Nissan D21 pickup flywheel
1983 280ZX Turbo clutch, both are 240mm. ... mine went into the car last night. *EDIT* The number of IMs I have received, responded to and proactively offered in response to this today has led me to offer up some clarification. Stock KA clutch contact is like what, 225mm? Start with the 1993 D21 pickup, whose flywheel bolts directly to the KA, it is 240mm. ... now comes in the issue of the need for a clutch to work with this. SIMPLE the 1983 280ZX turbo OR 2+2 has a matching 240mm clutch, which also shares the 24-spline pattern with the KA and HAPPENS to bolt right up in this application. When it comes to sourcing the parts, use google/NAPA/Vato Zone/pep boys or whomever you go through to find your parts at whatever the most convenient/costworthy means you see fit. Pilot Bushing: Specific to your engine Throwout Bearing: Specific to your transmission ... for the 2 previously named items, I WOULD have gotten 1995 items (matching my engine) if they weren't directly interchangable to the ones that came with the clutch SET that I bought. (compare part numbers before you find yourself screwed) ... from here, this is a normal clutch job, from which I will spare you the excruciating details. Remove everything, replace everything and DON'T forget the rear main seal like I did, caused an hour delay in my buddy getting the job done. Now you can go out and break your shiney new clutch and flywheel in |
Just out of curiousity, wtf is that?
I tried to google it, but it just gave me really great porn. |
^^^^ROFL
I think white bunny is the name of a guys car on FA. I think this should go into faq. EDIT: I found something interesting when i looked at the ACT catalog. Here is what will fit with the 240mm setup. ACT list these as all the same part numbers. They are all listed as 240mm. 280zx 79-83 2+2/turbo 300zx 83-89 non turbo 300zx 83-86 turbo 300zx 90-96 non turbo |
Someone call for a FAQ'ing. I'm the man for the job.
| All times are GMT -6. The time now is 01:30 AM. |
