-   Archive and FAQs (#/f/forumdisplay.php?f=11)
-   -   How To: recirc a Blitz BOV (w/pics) (#/f/showthread.php?t=27596)
uiuc240 04-28-2003 09:14 PM
1 Attachment(s)
OK, for those of you who have a Blitz BOV with the SMIC piping and are tired of driveability issues, I have the fix. Here are the parts you need:
Blitz steel IC pipe flange (phase2...$20 + shipping)
2 longer screws (M5 x 12mm)
2 flat washers (M5)
2 lock washers (M5)
one rubber hose (model 617 from Autozone, if that helps)
2 gear clamps
Start off by taking the horn off and replacing it with the flange...it fits perfectly. By the way, if you need to reposition your BOV, do it so it looks just like this. Here is the first pic:
uiuc240 04-28-2003 09:15 PM
1 Attachment(s)
This next pic shows the two places you are connecting...from the outlet of the BOV to the stock recirculating inlet on the intake pipe. Obviously, this trick needs the stock piping.
uiuc240 04-28-2003 09:17 PM
1 Attachment(s)
This is a dumb pic, but it shows the shape of the hose and the part number from Autozone. This one fit perfectly after I trimmed 1/2" off the bottom end.
uiuc240 04-28-2003 09:20 PM
1 Attachment(s)
this is the final product. if yours looks like this, you should be good. now, loosen up the screw on the top of the BOV and drive! it won't chatter now, and it's pretty quiet...but it works. i was tired of the ghetto way i had it before (ch-ch-ch-ch-ch-ch-chuuuuuh)
planb 04-28-2003 09:43 PM
Just a suggestion, maybe put some JB weld on tip of the steel flange/adapter, file it down to make a lip for the hose. so it wont pop off.
uiuc240 04-28-2003 09:45 PM
It's not under pressure, really. It's connect to the intake. I mean, the force of the air rushing out could budge it if I was making like 25 psi, but I'm not. But thanks for the suggestion...it'll make that mod if it ever pops off. :cool:
Eric
planb 04-28-2003 09:48 PM
thats true. but making things with jb weld is fuuuun!
kazuo 09-11-2003 07:38 PM
this one needs to be archived!
very useful for people who dont want to deal with that leaky-idle-ooh-im-gonna-stall-on-you ****.
BTW, I was looking for the hose using the part bumber you gave (617) but no luck -- do you have the measurements of the hose? I will just go to Kragen and try to get a similar one... Autozone is too far from my house anyways.
word.
SilviaDriver 09-11-2003 08:14 PM
yea i hear the Blitz bov leaks but would it leak under 7psi?
JDMark 09-11-2003 08:15 PM
nice write up uiuc, thanks! one quick question tho. just wodering how much quieter does it make it?
crioten 09-11-2003 10:37 PM
we need more things like this in the faq section
