89 ka24e cranks no start.
i have a 1989 240sx with a ka24e and today on my way to school it was starting good runniing strong. around 3 i came home parked it outside my house went in for a while and came back outside and car would not start. fuel is good can hear it prime nice and loud. checked fuel and its good, installed intake a few days ago and ran perfectly if not better. motor is a rebuild with 10k miles on the full rebuild. battery is good. starter is good, maf is plugged in, new ect, no fuses are blown. what could it be.. was driving good got home came back a hour later and wouldnt start anymore... what could it be? any idea.. help me brainstorm possible causes
anyone ?? have anything
Well id start at the basics and check for spark. And fuel and such.
i do have spark. and good battery
Try holding the accel. pedal down while cranking to see if it starts. Could be a bad IACV. Do you have emissions removed?
Have done that.too no luck. All emission parts there except catalytic converter
Pull ECU for codes.
no codes are present.. now the car wont crank over. turn the key and nothing ..
Start looking at the ignition switch. Could be bad at this point.
ok narrowed i tested the starter yesterday and it tested bad that shit was seized. Ok so i replaced it with a new one i go to crank it and its fine for now. i go to start it again this time i put starter fluid through the intake and it starts right up. but dies soon after. so it has to be a fuel related problem. i go to start it again and the starter keeps on spinning as long as the battery is connected. could i be a bad fuse?. thats stuck open? any help would really be appreciated
Also the car has good spark. put a spare coil
ignition switch is could be shorted out, thats why the starter goes on when the battery is connected. disconnect the ignition switch harness and reconnect battery. if the starter does not come on, switch is bad.
ok thanks. anyone know y i wouldnt have pulse to the fuel injectors
so does anyone know y i wouldnt have pulse to the fuel injectors
Swap with a known good ECU.
could it be a bad crank position sensor
Check grounds, just an idea. If you just replaced the intake and unplugged the maf, that would be the first thing I look at. Maybe the maf fuse went out?
Fusible link on the b+ side was bad that created no.injector pulse..car runs now
| All times are GMT -6. The time now is 10:55 AM. |
