-   -   Low Idle on Cold Start? (#/f/showthread.php?t=609817)
Kimosabi 08-13-2015 05:44 AM
Anytime I go to start my s13 in the morning it cranks over fine but it'll idle a little over 1000 rpm. It is not a rough idle it just idles low on start up.
Idle also jumps when coming to a stop. Are these things something I should be worried about? Will they give me problems down the line?
The car is an auto to manual swap with auto ecu.
Kimosabi 08-17-2015 08:10 PM
bump
I feel like this could be an IACV problem?
kruked 08-18-2015 06:21 PM
Same issue w/ cold start in the morning. Idles extremely low, (5-700ish) and seems like it wants to stall. Happens for about a minute or so and problem goes away. Normal idle is around 1200 on a regular basis have yet to figure it out because I never have the time to tear into it.
Kimosabi 09-11-2015 05:59 AM
yeah same no time at all. Runs and drives good apart from the valve seals causing a little smoke on start up so I'm really not that worried.
zombiewolf513 09-11-2015 06:05 AM
Check your throttle body, if I'm not mistaken there's a little pin like thing that is supposed to hold open the throttle a little during cold start until the water heats up and it retracts
cotbu 09-11-2015 03:02 PM
ummmm!:tardrim:
