-   South Eastern States (#/f/forumdisplay.php?f=39)
-   -   Need help with swap (#/f/showthread.php?t=532545)
SevenWays 08-17-2013 05:21 PM
s13 SR20 Fuel Pump not priming HELP!!!!
I just finished my Sr20 swap but my fuel injector is not priming, i checked all my grounds, my fuel lines are correct. 1 thing i forgot was the ignition chip after i tried to start the car. The battery is fine and the fuel pump is fine and all getting electricity. there is gas in the car aswell, can anyone help me?
also replaced the fuel pump relay with a new one and still nothing.
Does anyone know where this goes?
http://i8.photobucket.com/albums/a20...psbeddd1da.jpg
rubhamusan 08-29-2013 07:57 AM
If the injectors are not priming then orange wire start signal on the dash plug is not wired up.
SevenWays 08-29-2013 04:48 PM
there is no gas getting to the engine, i unplugged them and no gas comes out. The after market fuel pump doesnt prime, so i took it out and then put the stock and still nothing, and the connector in the back gets 12V
SevenWays 10-22-2013 02:22 PM
Can anyone help me out??????????????????????
