-   Engine Tech (#/f/forumdisplay.php?f=96)
-   -   Ka24de no spark or fuel (#/f/showthread.php?t=576311)
JDMBart 08-30-2014 06:13 PM
Stock ka24de. Was driving it one day and it suddenly turned off. Rolled it to a stop and haven't been able to start it since.
It cranks and has compression but not fuel and no spark. What could the issue be?
I swapped the distributor, didn't make a difference.
I also swapped out the dual cam ecu with a single cam ecu (I believe it should still work) but still no spark/fuel.
What could it be? I checked and re checked all my Fuses and grounds
goldens14 08-30-2014 07:13 PM
Check what codes are on the ecu
No 240.. No id 08-30-2014 07:42 PM
thought u got a sr instead lololol
JDMBart 08-30-2014 07:44 PM
I did get an sr.. The donor car I got has the ka inside of it. Look at my build thread
JDMBart 09-01-2014 10:27 AM
bump, redid all the grounds and also added a few extra to the chassis. still nothing
goldens14 09-01-2014 10:15 PM
Do you hear the pump priming when key is in the on position?
LoganDavenport 09-02-2014 01:00 AM
Any codes?
JDMBart 09-02-2014 09:53 AM
Yes the fuel pump primes and the fuel filter gets the gas but I'm not sure if it goes into the fuel rail because the spark plugs are always dry
JDMBart 09-02-2014 09:54 AM
I will check codes today
theboy 09-02-2014 10:51 AM
If its no spark or fuel check the dizzy. Also check the wiring to the dizzy to make sure the shielding around the signal wires hasnt rubbed through and mad contact.
SOHC ecu and DOHC ecu are not interchangeable.
JDMBart 09-02-2014 08:18 PM
I checked the ecu and got code 55 which means it is not throwing any codes. Got a new ignition coil from autozone and still having the same problem
goldens14 09-02-2014 08:44 PM
Can it push start?
goldens14 09-02-2014 08:45 PM
Check the charge of your battery too.
goldens14 09-02-2014 08:46 PM
And check the fusible link wires, those were messing my car up 2 months ago. Because it wasnt allowing my alt to recharge the battery
JDMBart 09-02-2014 09:22 PM
No spark so I don't think push start will help. The fusible links seem fine. Battery has been recently charged
goldens14 09-02-2014 10:57 PM
Push start would eliminate it being a starter or anything in the ignition..
goldens14 09-02-2014 10:59 PM
If there's a short between the ignition (have you checked the neutral switch) and the spark plugs, push starting it will work.
