Ka24e high idle need help!
Idle is at 1,500 - 2,000 and I'm running super rich.
My ecu was throwing code 13 and 41 coolant temp sensor and air temp sensor. I replaced coolant temp sensor so now I only have code 41 Things I've done: Cleaned iacv Adjusted tps too .45 volts Replaced coolant temp sensor Disconnected tps and adjusted idle screw all the way in and it still is at 1,500 rpms I tried timing it but my timing marks move around too much. Reset ecu Sprayed carb cleaner around hoses to check for vacuum leaks and nothing. Anything else it can be? |
| All times are GMT -6. The time now is 04:19 AM. |
