Installed Koyorad N-Flow on SR20DET, still running hot
So I just installed my Koyorad N-Flow on my sr20det, I was expecting for the new radiator to cool everything down but instead it still running hot :confused:
Basically it still running the same temperature as if I had my stock radiator on. I flushed the radiator, switched on the heater to let the air out which alot of bubbles came out, and filled it to the top with coolant in the radiator. I took the thermostat off awhile back, so I know that's not the problem. No leaks anywhere in site. Wtf is up with the heat? :ugh: |
How are you determining that it's running hot?
Actual gauge? |
I hope you also upgraded the radiator cap or at least replaced it. If it doesn't hold pressure, you will always boil coolant and overheat. |
I for sure would definitely not go by the stock gauge. Those things are really faulty.
But you should see a nice decrease in the overall coolant situation. Not to sure why you arent now, but for sure, if not the thermostat, not the new radiator, then by all means shoot for a nice aftermarket water gauge. |
Get a thermostat and check on the fan assembly. If a clutch fan is present make sure it's properly shrouded. Electric fans make sure they are functioning correctly.
Do you have anything between the radiator and free air or between the fans and radiator? Have you done a hydrocarbon test, or leak down? Do you know if the headgasket is blown? Forget all that if you just wanted the temp to be lower by installing a radiator! Sent from a Highly Tuned Note 4.5!!! |
compression test can help you diagnose that, or there is a reactive that changes color with carbon. Take some of your coolant and put some on that.
also put that thermo back in, let it do its job, and get a proper gauge. OEM one is not linear at all. If you removed the undertray and/or slammed the car, hot air has nowhere to go, so you could install a 20" thick radiator with a massively flowing fan, it would not matter. Otherwise the usual reasons these engine overheat is when timing is retarded and/or fuel delivery is bad. You may have all these problems, so instead of trying to fix the consequences, address the problems. |
^^ Really hope i don't have my headgasket blown, but i will check that out. And nah my car is not slammed, just somewhat low but clear bumps like nothing lol.
Also i started noticing that ive been loosing coolant even though i would top if off with coolant in the radiator and resevor. Still no signs of leaks or puddles underneath. Is my coolant getting evaporated by the heat or what? What would cause this? Headgasket? Honestly, i did not start having these new problems when I installed the koyorad :bash: |
Coolant cannot evaporate if it stays in the cooling system. If it goes lower, it means it gets burned in cylinders or in the turbo, or there is a crack somewhere... or you got a leaking hose somewhere.
Check your hoses clamps too. I thought i had a HG at some point, turned out i had a leaking hidden hose clamp. |
Another quick way to see if you are burning coolant is; you pull your plugs and look in the cylinder. The spark plug that is shiny will probably resemble the cylinder it came out of. This would indicate a headgasket failure as well. You're basically steam cleaning that cylinder so it'll appear cleaner than the others.
| All times are GMT -6. The time now is 12:38 AM. |
