-   -   Ka24de (s13) crank, no start (#/f/showthread.php?t=644080)
Shukize 03-30-2017 01:45 PM
Yet another crank, no start issue.
What I've done:
- new fuel pump (it works)
- new fuel pump relay(s)
- crank set at tdc
- new distributor
- car has spark, air, and fuel
I know this is a longshot, but does anyone have any advice?
Bmx240sx 04-06-2017 10:00 AM
The car just cranks doesn't start?
jusfor11 04-09-2017 08:13 PM
Major vacuum leak?
Shukize 04-10-2017 08:35 PM
Thanks for replying guys, I really appreciate you. Could be a major vacuum leak but I doubt it, don't see anywhere it could possibly be coming from. And yep, just cranks and won't start. I got it start once when I changed the ecu from a #25 to #29, but then when I tried to start it again, I smelt a electric burning smell and the car just continued to crank. I opened the ecu and everything looked fine. Very confused :-/ ...
Bmx240sx 04-10-2017 08:40 PM
Try swapping the ignition coil
Shukize 04-11-2017 07:43 AM
Did yesterday, no change.
Shukize 04-12-2017 12:40 PM
So the fuel pump will only turn on if I use a paperclip, and not with the relay. I'm thinking the fpr might react the same way. But why is this? Never take on other people's projects....
Bmx240sx 04-12-2017 10:23 PM
I had an issue like that recently and it turned out my ecu wasn't fully tightened
Shukize 04-13-2017 11:06 AM
I was hoping it'd be something that simple. But what I've discovered is, it's one of three things:
- ECU
- Injectors not opening
- FPR
apex128 04-13-2017 01:22 PM
Try and check your fuel pressure somehow. Make sure the car is getting fuel at all. Even if the fuel pump makes noise it could still be dead. Also, as dumb as it sounds, check the fuel sending unit to make sure the lines are hooked up correctly. When I did my fuel pump, my brother and I hooked up the feed line to the return on the fuel sending unit. The pump was sending fuel through the system backwards lol. You never know who worked on your car last or what they did. (Or maybe you do), but I would still recommend check these two things.
Shukize 04-14-2017 01:40 PM
Thanks, I'll give it a shot.
Shukize 04-18-2017 10:10 PM
What I do notice is when I try to start it sometimes I hear a loud pop (like an air releasing sound) coming from one of the injectors, maybe the 3rd. But I don't think that'd be the reason it doesn't start? Idk...
Bmx240sx 04-20-2017 05:08 AM
Did you check the codes from the ecu ?
Shukize 04-20-2017 09:59 PM
Alright, problem solved. The idler sprocket bolt isn't threading on. Might not be the original, need to find a oem bolt or a slightly bigger & longer bolt.
EDIT: Also changed ecu and that fixed the fuel problem.
apex128 04-21-2017 08:57 AM
Glad you found the issue.
Bmx240sx 04-21-2017 04:14 PM
x2
