-   Mid-Atlantic States (#/f/forumdisplay.php?f=33)
-   -   New Guy (#/f/showthread.php?t=102295)
570SX 02-23-2006 07:46 PM
New Guy
Just picked up a 240Sx for a motor swap project. I am in Central NJ area. Anyway doing a LS1/6spd conversion in about 60 days. Hence the name !!!Will be autocrossing and road racing her , as well as hitting the streets from time to time. Look foward to hanging around. Gotta convert to 5 lugs and need a non pop up headlight conversion and JDM fogs to get her looking well. She's a coupe not hatch in case anyone is wondering....
570SX 02-26-2006 02:33 PM
Wow this is a pretty lukewarm reception. I was hoping to really get some support for the suspension and brakes mods. Im gonna take a guess and say everyone hates the LS1/T56 combo. Think of it this way .... Its lighter than a RB26 conversion and way cheaper. Its slightly more than a SR20 conversion and weighs 110+ lbs less than a KA motor/trans. So figure 155hp/160lb-ft for a KA vs 315hp/335lb-ft for a LS1. In a sub 3000lb car means way fast.
EchoOfSilence 02-26-2006 02:42 PM
I'm loving the idea, but I'd be scared of traction issues under autocross conditions. I think the only reason you're not getting that well of a receptiion is cuz this isn't on the main page under the Newcomer thread. But good job on knowing to use this subforum.
Let us know how this swap goes!! I wish I had the money.
570SX 02-26-2006 03:23 PM
Nice name Echo... I have a friend with a RX7 and a LT1/T56 swap and like 4.10gears or so... Anyway traction is not a problem. Throttle modulation might be problematic when he's excited LOL but its very managable. Not mention the ability to use a higher gear and let the torque pull you thru.... Traction whether turbo or v8 is limited by the narrow rear fenderwells. A 30-50mm flare is needed to run the 275 or 285 series tire I plan to run.
EchoOfSilence 02-26-2006 03:49 PM
275/85? :eek3: wow man. good luck on that. I think that's a little overkill, don't you think? 255's would be fine
570SX 02-26-2006 05:00 PM
No , not for the torque and throttle response this motor has. I can go with a 17x9 CCW wheel on a 275/40/17 tire. Thats is of course a wheel built to spec with rolled fenders. But I thought the flares would look killer on the car !
