radio and clock resets?
I have a s14 and when ever I turn off my car my clock and radio resets like as in if you was to take off the battery terminal. Do anyone know how to find the problem? I do have a clifford alarm hooked up. It use to never do this until I sold my tv out of it
check your fuse
But if my fuse was blown than it wouldn't work at at. Everything still works when I turn the key but everything is reseted everytime. I turn off the car
You probably have some wiring issue. Obviously if this happened after you removed the tv. You should start there.
| All times are GMT -6. The time now is 08:41 PM. |
