My s14 boggs, dies then runs great randomly.
So first off, I bought my s14 ka24de automatic and it ran super great for 3 months, then many problems came up and one after another a new problem would come up. Right now it runs great when it wants to, I could go on the highway and there are no unusual noises or anything and no bogging then out of the blue it dies, when I am able to get it going its extremely gutless and wont shift into second gear. It does not want to start when it dies, when I get it to fire up I gas it to keep it alive, black smoke comes out the back. The ignition timing is at 18-21btdc at 700rpm. So far i have replaced spark plugs, Idle air control valve and air regulator, a brand new engine harness from wiring specialties, tps, coolant sensors, all fuses(no relays), new 5 point grounding kit, and 02 sensor, no coolant leaks, no milky oil either. The owner before me did do a egr delete so some plugs on the harness are not used but no codes are thrown. The only code im getting is the IAT which i just ordered. Another thing that is odd with the motor now is that it does not die when i unplug the MAF, it used to die when I first got the car dont know if that matters. The only real thing i can think of is the distributor is going out, and a vacuum leak but there is little to none that are left after the egr delete which look good to me. I will not do a engine swap either. I hope its just one little dumb thing im looking over. If you need pictures of anything I will take some.
black smoke = fuel
as long as the sensors are working, (iat, cts etc...) It goes MAF -> ECU -> INJECTORS its a very simple engine. So you are looking for something that has to do with one of those 3 things If a sensor is bad that's different. So check your sensors, check compression, basic diagnostics, then look for an issue with the maf wiring or maf plumbing or fuel pressure or ecu grounds or ecu connection (the harness to ecu) stuff like that the sudden onset makes me think wiring related. But a bad sensor can do that too (goes 'bad' internally is a wiring short) |
Have you run the codes?
best place to start. Ive also found that the plugging and unplugging the maf test isn't a gurantee the maf is actually the problem, just gurantees theres a problem also have found when the distributor goes bad it doesn't like throttle. Breaking up under throttle and idling well, They may be able to fail in other ways IDK but from my experience that's how they generally fail hows your fuel pump doing? |
pretty much guessing at this point
maybe the ECU distributor or maf have failed |
Have you replaced the dizzy cap and rotor?
This fixed mine. |
Kind of a doozie without any codes. I feel like there would be codes.
When my brothers car kept randomly shutting off, it would not want to start again (I had it towed 2 times). He had no code originally. I thought fuel, so I replaced the fuel pump and sock. Same problem persisted. Later a code finally showed up for MAF and Knock sensor. Once those were done, problem fixed. Does your car still have power to accessories? My truck had a bad battery connection (from main power wire being pinched). |
Like, you pulled the intake manifold? What was wrong with your maf? Mafs fail pretty rarely, but are an obvious component that changes how the engine runs when you monkey with it, so people love fucking with it. |
its safer, like if you crash it will fold up instead of rip through the floorboard and impale you Its also more likely to drive right, In other words it seems like 40% of the time someone buys a 1piece driveshaft it isn't balanced or phased right and the car picks up an annoying vibrations Just don't... |
Carriers also deflect and absorb impact when you dump the clutch or hop a wheel or something. It's good to have softer systems that fail more gently, so you know before it happens. A carrier is the maximum benefit from the minimum compliance, keep it. |
| All times are GMT -6. The time now is 02:44 PM. |
