-   -   3x projector wiring q?? (#/f/showthread.php?t=251433)
robtech 04-15-2009 10:48 PM
ok so i just want to see if this sounds right to you guys...
when i got my sileighty someone jad jacked the front clip parts and just ripped/cut the harness so i've been sorta going from scratch to mate my factory headlight harness to my mangled one
for hi/low beams-
factory 3x harness has 3 wires
red with blue stripe
red with white stripe
red with green stripe
in the chassis harness there's a clump of 3 wires, same color codes...these go together correct? they didnt reverse anything in the jap cars?
for the fog lights (inner light on the 3x) i hook up the red wire to the brown wire from the popup motor harness and the black to black and they should work with my popup switch in the cab?
do i have this correct or am i smokin crack? thanks in advance
palmdale_mob 04-15-2009 10:53 PM
You got the foglight part right
I'm not too sure on the other wiring
robtech 04-15-2009 11:04 PM
yea thats how i have the hi/low hooked up cuz it made sense but they;re not workin..but we pieced the harness togethor out of a box so no telling the bulbs are good...or the popup relays are bad cuz if they are then the lights wouldnt come on so im still chasin gremlins a lil bit...'ill come at it with a fresh head tomarrow ngiht
palmdale_mob 04-15-2009 11:25 PM
Well I got dual halogens so everything was plug and play and I just hooked up the switch to the inner lights, so that was pretty simple
Just search how to do the rest of the wiring I'm sure its on here somewhere, if you can't find it try google
Also the problem could be something else with your wiring harness, since you said you pieced it from scratch
s13boy89 04-15-2009 11:27 PM
its not hard i did mine twice
