Very nice!! but i am more interested in the R34 at the back!!
and that red s15 hiding back there!
The R34 just got the bottom end all forged built with complete tomei head and HKS 2530s and the Red S15 we are in the process of building the roll cage since it will also be a drift car...
Well I went to Pro-Motion Distrbuting on Friday and picked up their final stock of the Sparco Pro2000 Seats as well as some aluminum side mounts.
I also got my Momo steering wheel hub but still trying to decide on which steering wheel to do with... Keep your eye out for the ETB Instruments DigiDash coming soon :) Check the seats out: http://alexvillabrille.com/wp-conten...40-225x300.jpg |
anyways.... what SR will you be using, and what are your power goals? |
We are going to be pulling the built SR out of our S30 but mate it to a Z32 trans for a stronger and more reliable setup.
The motor runs great and super strong and was dynoed at 508whp at 26psi and race gas... should be around 450-470 on pump. |
Been trying to clean up the rest of the interior so we can prep it for paint and begin to move onto the rest of the good stuff!!!
The rubber seem sealer is a pain in the ass to wire wheel all off, but it is finally done! Oh and I used dry ice of course to remove all the tar. www.alexvillabrille.com http://alexvillabrille.com/wp-conten...5/img_1042.jpg |
cool, will definatly be checking this thread, since there are no engine pics :confused:
Well this would have been a productive weekend usually, if we had actually liked the final turnout of the interior paint. We spent the entire day on Saturday prepping the car to be ready to paint and we got to the interior on Sunday morning and were going to start painting the exterior of the car but it was drizzling and not a good day to continue. The end result of the interior we didn’t like so much, but you guys be the judge. Going to re-paint it this weekend hopefully.
http://alexvillabrille.com/wp-conten...52-300x225.jpg http://alexvillabrille.com/wp-conten...54-300x225.jpg http://alexvillabrille.com/wp-conten...55-300x225.jpg http://alexvillabrille.com/wp-conten...56-300x225.jpg http://alexvillabrille.com/wp-conten...59-300x225.jpg http://alexvillabrille.com/wp-conten...60-300x225.jpg TODAY: We brought the infamous SR20 powered 240Z to rip its heart out! It was sad to take the car back home on a trailer but it had to be done at some point. In the future the 240Z is likely to get a 2JZ for some street fun. (Don’t mind the tow straps as were pulling the engine, its super light and didn’t have the transmission attached to it anymore) http://alexvillabrille.com/wp-conten...74-300x225.jpg http://alexvillabrille.com/wp-conten...76-300x225.jpg http://alexvillabrille.com/wp-conten...77-300x225.jpg Be sure to keep up on www.AlexVillabrille.com |
wow fukkkkken amazing
yes hell freaken YES!
put a KA-T in the s30!!!
hahah no KA-T for the S30. We already played with the KA motor in NA form for the 510 which is still up for sale and this time were going single turbo 2JZ for some easy street fun....
But again the 350Z project is priority now and the S30 is on the back burner for a while :( |
more pics of 240z please
Pics of the 240Z are back up and hosted on the SR240Z.com site: SR240Z | SR20 Powered 240Z.
anyways..prop for all the work!! |
A few updates over these past few days.
The motor pulled from the 240z was dropped into the 350z :) Fits very nicely and just need to modify the top-mount manifold so that the turbo clears the strut tower and is closer to the motor and further away from the brake parts. I went ahead and pulled the brake pedal (was automatic before) to cut it down to size and also install the clutch pedal and master cylinder at the same time. Brake booster and master were also set in place and re-installed We also got started on the re-wiring of the standalone and complete car. The factory wiring harnesses for the car weigh so much its ridiculous. This new EZ-Wire setup definitely comes in handy but is very time consuming. http://alexvillabrille.com/wp-conten...61-300x225.jpg http://alexvillabrille.com/wp-conten...30-300x225.jpg www.AlexVillabrille.com |
We are trying to have continuous updates and progress on the car while still working on customer cars during the day. These past two days I have been doing routine service and prepping cars for swaps while my dad started to work on the dash center panel.
He found some carbon sheet lying around the shop and got to fitting it into where the old navigation and Bose stereo used to be. The gauges fitted into the pod are temporary for fitment purposes only. Check it out: http://alexvillabrille.com/wp-conten...65-225x300.jpg www.AlexVillabrille.com If you go to the blog page you can click on all the pictures to view them in full size. |
wow that S30 is mad clean
looking forward to more of this build |
Chet at Galek Motorsports came through with the ETB Instruments DigiDash 2 Lite. It finally arrived today after such a long time in deciding what we were going to do with the central gauge setup.
We will have it installed and wired as soon as the rest of the sensors come in the mail and get some new lit up pictures! Dont forget that if you go to the blog page you can view the pictures in full size when you click on them. http://alexvillabrille.com/wp-conten...25-300x225.jpg www.AlexVillabrille.com |
Always been a fan of your guys swapped S30's, good luck with the build, its gonna be pretty sweet
I know I haven’t lived up to my word in supplying updates for this build but we have been hard at work trust me! UPDATED!!!!!!!!!!!
The entire blog post can be viewed at www.alexvillabrille.com Here is a preview: “…KA24 510 tuned but ended up blowing the motor due to tuner error :/ We brought the car back, pulled the KA24 and swapped in an SR20det instead…” http://alexvillabrille.com/wp-conten...61-300x225.jpg http://alexvillabrille.com/wp-conten...66-300x225.jpg “…new brakes for the 350z track car (Wilwood 6-piston front and 4-piston rear), new front windshield installed, as well as painting the roof…” http://alexvillabrille.com/wp-conten...68-300x225.jpg |
ooh. nice. I like the stitching. sweet.
fucking dope
wow im throughly impressed looks like a freakin awesome project
Nobody noticed the main hoop in the cage pics? WAY over 180* bends.
You'll never get that tech'd, I'm afraid. Quote:
The rulebook specifies that bolt-in cages are legal, but even if you run a bolt-in cage, they like them to be welded in. Here's where you can sometimes get hung up: Quote:
Our cage fabricator is going to re-make the main hoop if he has to.... We already told him the issue and he surpassed that when we gave him the rule book.
This 350z was the best deal I have ever gotten and it was a complete running car, but since it was pre-production it was not "allowed" to be registered...FREE!! |
| All times are GMT -6. The time now is 07:59 AM. |
