-   Engine Tech (#/f/forumdisplay.php?f=96)
-   -   Cranks but won't start (#/f/showthread.php?t=674091)
ilusive 05-19-2020 10:11 AM
Sr20det cranks but won't start
i have a red top sr, was running a week ago but it wouldn't idle and now it wont start.
It has spark, fuel, rechecked the timing and good compression. I'm lost at what could be the problem, the top end was recently rebuilt (it was running until recently when it decided not to start anymore)
jedi03 05-20-2020 08:43 AM
what happens when you try to start it? can you upload video showing as well? checked for codes?
ilusive 05-20-2020 02:19 PM
it will just crank but never actually turn over, but about a week ago it was running now it stopped. throws code 55, and for some reason it wont let me upload any videos
NukeKS14 05-20-2020 06:51 PM
so, upload it to youtube and post a link?
FaLKoN240 05-20-2020 10:30 PM
Cas? Tps ?
jedi03 05-21-2020 07:40 AM
so engine spins...do you have spark fuel air compression? also oil, gas in the tank etc?
ilusive 05-21-2020 10:58 AM
cas and tps are both good
it has good compression and the link to the vid is https://www.youtube.com/watch?v=DuMhwYr_9OA
Future240 05-21-2020 11:13 AM
You have another ECU you could swap in and check?
ilusive 05-21-2020 12:56 PM
yes but its for whenever it was a stock sr, the one on it now is tuned by martin
ilusive 05-28-2020 01:57 PM
anyone have any idea of what it could be?
S14rebuild 05-28-2020 02:21 PM
U say it has fuel....is that fuel pressure, or physically fuel sprayn from the injectors?
ilusive 05-28-2020 02:38 PM
it has both fuel pressure and the fuel spraying from injectors
brndck 05-28-2020 04:04 PM
cranking and turning over are the same thing.
starter engages with the flywheel, physically rotating the flywheel, which turns the rotating assembly, "turning it over".
FIRING is something else entirely.
F.A.S.T.
Fuel
Air
Spark
Timing
check those 4 and report back. you have at least 1 missing.
jedi03 05-29-2020 10:34 AM
while someone is cranking w/valvecover off see if the cams spin, ground plug against intake to verify spark...
brndck 05-29-2020 11:13 AM
wait. it was running, THEN you "rebuilt the top end", THEN it wouldn't start?
or
it was running, you rebuilt the top end, it was STILL running, THEN it wouldn't start?
ilusive 05-29-2020 01:17 PM
it was running, then the top got rebuilt, then it randomly stopped after I fixed the cas and put a new tps in
Future240 05-29-2020 01:23 PM
Have you checked it with another CAS or TPS? I know you said they were good, but the fact it stopped running after you changed these two variables kinda points to one of the two.
ilusive 05-29-2020 01:27 PM
to be more clear, it was still running after I put the new tps on and and fixed the cas, it was out of timing, then I went to try and fix my idling issue the next day and it stopped running
so is it the cas then?
S14rebuild 05-29-2020 02:03 PM
timming is still fukddd
If ur cas was bad ud have no injector pules/sparky
jedi03 06-02-2020 12:43 PM
prob cas just a tooth off or close...so easy to get off
ilusive 06-08-2020 01:06 PM
quick update, I replaced the spark plugs and reset the timing completely. now it seems to pop like it's about to start first time starting everytime then it'll just crank and flood the cylinders
S14rebuild 06-08-2020 01:17 PM
Set mechanical timing properly then put the cas in properly...
ilusive 06-08-2020 06:12 PM
yes, I set the mechanical timing properly and the cas is installed properly
ilusive 06-14-2020 08:26 PM
fixed the problem, my fpr blew, just replaced the fpr and it started right up
S14rebuild 06-15-2020 04:34 AM
You said you had fuel aka proper fuel pressure.....
Either or glad its running
