Northborough MA swap meet 11/22 - lots of parts to be had!
I know this is a last minute heads up but 240sxone put together a local swap meet before the end of season.
The Date: Sunday the 22nd of November The Location: Arthur's Pizzeria Address: 10 Blake St. Northborough, MA The Time: 12:00PM Noon and on throughout the afternoon. there is a whole thread on what everyone is bringing on 240sxone. and here is my list I can bring any of the following if anyone wants: Sandblasted & Por 15'd Rear Subframe with Nismo Subframe bushings installed: $200 S15 Helical Diff installed in pumpkin by dsg with axles: $550 Megan Rear Camber arms 0 miles on just installed and adjusted: $100 Megan Rear Traction Rods 0 miles on just installed and adjusted: $75 Megan Rear Toe lower Rods 0 miles on just installed and adjusted OEM camber bolts 2 Used $5 for the pair and 2 new $10 for the pair Can Bring a Perfect running Finned Red Top sr20det (marroon top) known for being a late model with black top internals and oil pickup with tranny and with full wire harness conversion done, new iridium plugs, ignitor, maf, ecu, new coolant temp sensor, new toda flywheel, new copper mix clutch, icv cleaned out- had this isntalled and running but never put miles on it turbo is perfect condition- $1800 Greddy Ti-C catback exhaust- installed and started motor with this on the car but never left the garage- cant find silencer tho- $390 Megan Test Pipe- Same as above 0 miles on it- $45 RSR ceramic coated downpipe has a couple light scratches on it from a steep incline from getting into the garage- $100 megan racing turbo outlet elbow to downpipe 0 miles motor just started with this on- $75 oem rear A arms with energy suspension bushings installed- one needs new balljoint-$25 for the pair and those bushings suck to install and took me about 5 hours mint center console with both ashtrays-$50 Brand New in box Koyo Radiator for sr20- $300 Brand New in box Flex-A-Lite FAL-220 Dual 12 inch Puller Auto Electric Fans 2500 CFM $190 Brand New Samco S13 Sr20 upper and lower silicone coolant hoses- $60 - Black APEXi 507-N004 Dual Funnel Power Intake Kit S13 SR20DET- Never Used, polished by hand - $85 Work Aluminium Red Lug Nuts Barely Used-$65 New Single Flex-A-Lite Fan- by itself- $60 Brand New in box Dif electric dual fan controller with built in relays- $120 s15 chaser vented Hood with oem s15 hood hinges- $100 s13.5 conversion fenders origin and chaser- origins were installed but not painted and chasers are brand new $75 for each pair Im sure i have even more stuff i need to go through. PM me if you definatly want any of the big stuff to make sure i bring it! Check my previous posts as i have posted pictures of pretty much everything! |
| All times are GMT -6. The time now is 07:11 PM. |
