Blown/melted pistons/rings or so I thought! sr20det
So long story short I was driving down the road in my car and it was running very rich due to a bad fuel map but It cleared up once I was in boost. Bone stock sr20 that has been around me for 3 years
50 trim turbo, 555cc injectors, tune Etc.etc I floor it and It over boosted by like 15 psi (30psi) and then boom! Subaru sound and white smoke, I pull over and shut the car off and check the damage oil everywhere from the maf (piston rings I assume) fine. So i assumed it was the pistons so I let it sit and lastnight I tore it apart only to find the following! 1.pistons are not melted or damaged 2.rings are in tact and not cracked or melted 3.coolant in number 3 cylinder but the car didn't over heat and didn't eat a single drop of coolant. the head gasket was also perfectly fine when i pulled the head off, i seen no ripped marks or anywhere it was damaged. 4.cylinder walls are not scratched or scortched 5.no pitting on combustion chamber head or block 6.valves look good but I'm doing a valve check as we speak I am stumped at this moment as to what the hell happned! Has anyone ever encountered this before? Could the head have cracked under pressure? I would think the head gasket would give or something would melt before the head and or block would crack I'll post pics in a little bit to show you guys whats goin down There was a little sign of number 4 piston started to pit a little bit but nothing that would stop it from running or not make compression |
Must of been that Godspeed intercooler , what a asshat
What about the bottom end?
Rods are in good shape and the main/rod bearings don't show signs of damage or scratching. everything looks good lol it's like nothing happened inside of this engine! only the coolant in cylinder 3 |
have you looked at the turbo..
long before that 900rwhp cobra he posted |
The injectors were inspected and in working shape The coilpacks are being used on a friends car |
Don't question it man. Roll with it.
Perhaps what you heard was a coupler blowing off? 30psi can make a big bang and smoke.
Is why you can't assume things. A compression/leak down would have saved you all that trouble... A boost leak test would indicate coupler failure. Now you have the whole block apart... |
I know it wasn't running on all cylinders when it happened cause that sound is all too familiar. It had all symptoms of melted piston or blown rings, I've melted rings and pistons before |
I know the electrical was all fine, coilpacks are good and injectors are good. All things that would make it not run on all cylinders, I'm about to post a video in a little bit so you guys can see and if you read It had cylinder 3 filled with bright green coolant so something happened inside. |
Or perhaps oil got all over the maf and shorted it out, causing it run like a subaru? Or maybe you lifted the head a bit?
If you sprayed oil all over the bay then you obviously pressurized the crankcase. There is only three ways this could have happened. PCV valve broke allowing pressurization of the crankcase.
Cracked the ring lands or melted a piston (which you said didnt happen) Or lifted the head pressurizing both the cooling system and crankcase. If you were on factory headbolts then you probably lifted the head. The gasket really wont show damage if this happens. It will just lift allowing boost into the oil and coolant and then reseat itself once out of boost |
Factory headbolts dont like much more than about 400whp. and on that turbo and 30psi, even though you dont have the fuel for it, it was probably making over that and probably started to get some detonation from leaning out which only will escalate head lift.
Its supposed to jiggle. You need to blow into it where the hose would connect and see if excessive amounts of air goes by the valve. It wont seal completely but it should be close.
You probably lifted the head if stock headbolts were used.
Found out anything on this?
| All times are GMT -6. The time now is 04:49 AM. |
