-   Engine Tech (#/f/forumdisplay.php?f=96)
-   -   cp piston ring install/orientation? help (#/f/showthread.php?t=476768)
kouki_drifter 09-12-2012 09:48 PM
ok i just bored my s14 sr20det 20 over to 86.5mm, i bought me some CP pistons and the instructions suck! no clear explanation on how the rings should be orientated on the piston, like oem 90deg of each other or different like wiseco?. also I am wondering the difference in ring gap from oem 86mm to the new 86.5mm? ive already googled it and searched with no answer, if anyone can help me out i would appreciate it!
KoukiMonsta 09-12-2012 09:50 PM
I used oem orientation for my cp pistons
Also checked ring gap according to cp instructions, it's been a minute but I think they were all in spec didn't need to file anything down.
Hope that sheds some light
kouki_drifter 09-12-2012 09:53 PM
this is all that was included with the pistons, the link all the way at the bottom of the page
Piston Tech
kouki_drifter 09-12-2012 09:55 PM
thanks! i was wondering? because i had wiseco pistons on the motor before and the instructions on ring orientation was way different from oem, just wondering if cp instructions are the same? what size pistons are you running?
oni jake 09-13-2012 01:05 AM
Use OEM specs for the orientation.
As for ring gap, on a turbo application, it is Bore (in inches) X .0055 = Top Ring Gap.
86.5mm = 3.40551in
3.40551in X .0055 = 0.018730305in
Top ring gap should be .0187in
The next ring is simply .004in to .008in over. So, shoot for .025in.
We just this on our SR with CP pistons and found that the gaping was not correct from the factory. So please, make sure you take the time you do this.
Walperstyle 09-13-2012 05:43 AM
I replied in the other thread about filing your rings, but here^that guy seems to have helped you. Listen to him.
kouki_drifter 09-13-2012 07:19 PM
Sounds good man thank you! One more question which side of the piston goes to the front of the motor? The wiseco pistons are labeled these aren't
kouki_drifter 09-14-2012 12:03 AM
thanks! anyone know how the pistons go installed? which side goes to the front of the motor? or does it matter? my previous wiseco pistons were labled fwd-> these CP pistons are not? now if i have to file the ring gap i do not have a ring gap file, can i use a dermal with a metal cutting disk and just mount it in a vise and squeeze the ring gap around the disk and file that way? or file by hand?
Walperstyle 09-14-2012 12:32 AM
If you file by hand, take your time. Don't take too much off, and keep checking with a spacer/feeler tool.
kouki_drifter 09-14-2012 01:32 AM
Ok so how does the piston mount to the rod which side faces to the front of the motor? Does it not matter?
Walperstyle 09-14-2012 05:32 AM
I didn't answer because I'm not 100% sure. I have CP 8.6:1 for my KA-T but I can't exactly inspect them at the moment.
kouki_drifter 09-14-2012 10:39 AM
Hmm it's kind of weird that they wouldn't be labeled, even of it doesn't matter why not label any way to get rid of the guess work ?
kouki_drifter 09-14-2012 02:40 PM
Ok on #1 ring gap I have .014 / 0.35mm on my filler gauge so I must be at .018 /0.45mm?
kouki_drifter 09-14-2012 04:20 PM
Ok #1 is at .018 #2 I got a little file happy I guess and went to .026 which is ok
Pinggg 09-15-2012 12:31 PM
If it's giving you that much problem just let a machine shop assemble it.
That's not something you want to mess up on and think it's right.
kouki_drifter 09-19-2012 01:21 PM
na i got it done no big deal
