Starter won't engage flywheel
Ka24e freshly rebuilt and dropped in won't crank, the starter just spins and sounds like an rc car when I turn the key. I've tried just about everything including new battery, new starter, checked all grounds, new blue starter relay, cleaned all connections. Solenoid reads about 6 volts and I read it should be 12v, so I believe its an issue with that but I can't for the life of me figure out what it is. I also tested the old starter (after buying the new one bc I'm an idiot) and it worked fine, so that rules out the starter I would think.
Edit: tried hooking the little plug connected to the solenoid straight to the battery and it just makes the starter spin like it was before. Could this mean its bypassing the solenoid somehow? UPDATE: I was able to make the starter solenoid "engage" by wiring it straight to the battery, but not spin at the same time. When I go to turn over the car I can hear it engage at least partly but it seems to not go all the way or something. Other info: Headlights also stopped working, they're hooked straight to the battery with a fuse (intact) and switch in between. The car has a fuel pump kill switch in between the fuel pump and ignition switch, not sure if this would change anything. |
Is the engine spinning or just the starter
What would this trick be? I replaced the relay and still no result.
my bad, i misread the hell out of your post. Is the engine spinning too or just the starter?
Nope just the starter lol. The starter won't engage the flywheel so it just spins freely
and when you popped it straight to the battery it worked fine?
Okay stupid question... Is it possible to install the flywheel backwards and still have everything "fit together"? Got starter solenoid to work but still wont touch the flywheel.
No, theres locating pins for the clutch cover sticking out away from the engine.
Ur sayn flywheel.....just wanna confirm this is a manual transmission
Yup 5 speed
So I just pulled everything apart to find that the back of the crankshaft that bolts up to the flywheel is thicker on the new crank by about a centimeter. Other than that its exactly the same. Looks like i solved my own problem with another problem. Just out of curiosity, anybody know what this crank might be out of? Is the 4wd ka24e different than the 2wd?
You pulled the motor out and apart? How did you take that measurement? Can you put the other crank back in?
| All times are GMT -6. The time now is 03:14 PM. |
