FS s13/sr20 parts/garage clean out
All parts located in Vegas
Pick up welcome Price does not include shipping or paypal fees Everything can be shipped at buyers expense All parts in good working condition unless otherwise stated Everything is OBO PM me for any questions Best way to get a hold of me is by text 7o2 595 48 1 5 SOLD SOLD SOLD1. $300 S14 T28 journal bearing turbo good condition maybe 3-4000 miles since rebuild, no smoke, minimal/normal amount of shaft play does not touch housing. https://i.ibb.co/bJPNmR7/20181231-175841.jpg https://i.ibb.co/jkh3L4f/20181231-175850.jpg https://i.ibb.co/qCdM4Mq/20181231-175925.jpg https://i.ibb.co/HVXyMM2/20181231-175932.jpg 2.SOLD SOLD SOLD $150 S13 pop up light assembly Everything pictured is included https://i.ibb.co/0hg69MZ/20181231-175439.jpg https://i.ibb.co/GdCbghc/20181231-175443.jpg https://i.ibb.co/CPM5GBz/20181231-175456.jpg https://i.ibb.co/ygkkPrK/20181231-175500.jpg 3. $150 AC compressor and bracket condition unknown never ran removed from s14 sr20det block. https://i.ibb.co/2n5RC4v/20181231-180312.jpg 4. $OLD SOLD SOLD 25 S14 water neck/outlet https://i.ibb.co/30dmTW4/20181231-180346.jpg https://i.ibb.co/HYdZLNv/20181231-180350.jpg 5. $25 S14 SR20 water pump used removed in good working condition https://i.ibb.co/qY6ZYZW/20181231-180354.jpg https://i.ibb.co/Jt4FQz9/20181231-180359.jpg 6. $25 wrx bpv bov https://i.ibb.co/sQ1JdWT/20181231-180412.jpg 7. $60 new genuine nissan sr20det timing chain tensioner https://i.ibb.co/qDqPLV6/20181231-180432.jpg 8. $25 sr20 rocker arm stopper not sure on brand circuit sport or p2m https://i.ibb.co/whBcZxP/20181231-180504.jpg 9. $10 s13 center vent gauge pod 60MM https://i.ibb.co/TvhGn8P/20181231-180515.jpg 10. $120 s14 sr20det maf modified to fit hose over housing no adapter needed, ran this over 5 years no issues. https://i.ibb.co/JyDjpp5/20181231-180529.jpg https://i.ibb.co/nnXCmDc/20181231-180532.jpg 11. $25 s14 sr20 oil pick up https://i.ibb.co/ZH7YMtR/20181231-180553.jpg 12. $40 s14 sr20 vct camshafts https://i.ibb.co/J7YGjPL/20181231-180603.jpg 13. $10/each Top is subaru vf39 wastegate bottom is godspeed adjustable https://i.ibb.co/wWVphdS/20181231-180621.jpg 14. $25 S14 sr20 oil cooler https://i.ibb.co/vjntz6K/20181231-180632.jpg 15. $100 s14 sr20 turbo inlet hose https://i.ibb.co/cFtYRtj/20181231-180653.jpg 16. $50 sr20 crank pulley chipped ran fine https://i.ibb.co/BwxdXh9/20181231-180704.jpg https://i.ibb.co/xh2jz4q/20181231-180710.jpg 17. $100 s13 cluster bezel all switches pictured included https://i.ibb.co/d2BHsfC/20181231-180721.jpg 18. Scrapped $25 late 90's maxima inner tie rods cut to fit gktech extend knuckles 19. $25 p2m s14 offset rack spacers 20. Scrapped $25 oem s14 outer tie rods 21. Scrapped$25 p2m s14 outer tie rods https://i.ibb.co/v4kjGcV/20181231-180738.jpg 22. $100 sr20 flywheel/clutch condition see pics never used came with the trans clutch has some life left flywheel has few glazed spots. https://i.ibb.co/RTt9T8m/20181231-180818.jpg https://i.ibb.co/VxHqfVM/20181231-180817.jpg https://i.ibb.co/7prsRBR/20181231-180814.jpg https://i.ibb.co/KmYJdnH/20181231-180826.jpg 23. SOLD SOLD$150 s14 sr20det pistons and rods removed from running car due to bad rings https://i.ibb.co/8x7byfm/20181231-180919.jpg https://i.ibb.co/Htmjdyc/20181231-180928.jpg 24. $10 s13 oem ruca 25. $10 s13 oem trailing arm 26. $100 front knuckles https://i.ibb.co/rG1WNs8/20181231-180936.jpg 27. $OLD SOLD SOLD 50 fmic core only removed from wrx godspeed (ebay) https://i.ibb.co/R3W1zkY/20181231-180942.jpg https://i.ibb.co/QnMCMzR/20181231-181000.jpg 28. $40 s13 front sway bar oem https://i.ibb.co/GRqpVJY/20181231-181012.jpg 29. $120 s13 non abs driveshaft new carrier bearing 30. $15 gplus (ebay) sr20 radiator hose kit 31. $40 ignitor pulled from running s14 sr20det can include pigtails if needed for $5 more 32. $50 Sr coil pack all 4 were pulled from running car can include harness for $25 more. |
Bored at work Saturday AM bump
Bump it all the way to the top
Bump, where did you get your T28 rebuilt from? and how much was it?
Ebay cant remember 40 50 maybe it was few years ago it was the cheaper bearing I guess there is a more expensive 270 degree bearing or something
To the top
bump to the top
Bump it up
Bumper stickers
To the top
Bump it up
All the way to the top
Bump few items added
To the top
I have a friend looking for the cluster. He is local.
If you have Instagram maybe you can dm him. His username name is My_kull. Thx |
Best way to get a hold of me is cell at the top
Bump to the top
bump this up
Bump to the top
Bump to top
| All times are GMT -6. The time now is 04:16 PM. |
