-   Archive and FAQs (#/f/forumdisplay.php?f=11)
-   -   180sx position/bumper light install (#/f/showthread.php?t=169993)
ALEXTHESUS*PECT 12-26-2007 03:37 PM
when you get a kit or change to a type x front bumper you will need to wire in the front bumper turn signals. here is everthing needed:
http://i60.photobucket.com/albums/h1...se/pics011.jpg
housings:
http://i60.photobucket.com/albums/h1...se/pics013.jpg
new bulb harnesses:
http://i60.photobucket.com/albums/h1...se/pics012.jpg
you will also need wire cutters, electrical tape, and soldering gun if you have one.
start off by pulling out the harness on the car for the bumper light and cut it off.
http://i60.photobucket.com/albums/h1...se/pics016.jpg
http://i60.photobucket.com/albums/h1...se/pics017.jpg
as you can see there are 3 wires; black, green/yellow, red/blue. strip the covering from the two colored wires, and then again on the new light harness. i trimmed the black and taped it over by itself with the electrical tape. then coneect the old light harness and then new one:
http://i60.photobucket.com/albums/h1...se/pics015.jpg
plug in the bulb and make sure it works for the driving lights and blinks for turn signals.
http://i60.photobucket.com/albums/h1...se/pics018.jpg
Tape everything back up, and tuck back in the harness into the bumper. put the new bulb into the new bumper light, and you are all done!:rawk:
mr_240sx 12-26-2007 09:36 PM
are you serious? i thought i could only have either turn signal or running lights.... you sure it works with the ground un hooked?
tks a bunch, ill go try that next time im working on the car!
ALEXTHESUS*PECT 12-26-2007 09:39 PM
yeah i'm sure. if you use the black/ground then only one will work. but if use both the colored wires then they both work.
mr_240sx 12-26-2007 09:50 PM
tks Alex, ill try this out next time i work on the car!
A Spec Products 12-27-2007 08:45 PM
Yeah
I did it the same way
So it lights up in on position but still blinks when turn signals are on
I didn't buy the actual harnesses though (Origin markers only come with the housings, no bulbs/sockets/harness), I just used rear side marker bulb socket/harness that I trimmed to fit
mr_240sx 12-28-2007 12:02 AM
i hooked it up this way tonight and its true, it works for both positioning lights and flashers.....the only thing is i found it flashed differently now. how can i say it, it has some sort of unpredictable flashing now. itll flash 4 imes the same speed then 1-2 times really quick and then goes back to normal and it continues doing that. i found it only does that when i have lights turned on. when lights are off the signals are fine!
ALEXTHESUS*PECT 01-07-2008 10:03 PM
not sure why. i didn't have this problem.
btw how come this isn't approved yet?:axe:
mr_240sx 01-07-2008 11:18 PM
all i know is this has been performed and it works! youve got my thumbs up for you Alex!
powersteeringless180sx 02-11-2008 11:26 AM
aww shit i never knew you could do this.... i just spliced the wires from the front sidemarkers but i'm gonna do this instead cuz i don't have blinkers in the front. +1!!
kousuke180sx 03-14-2008 04:38 PM
I tried this today and it worked perfectly, thanks alot!
