-   -   Scott's 92 S13 (#/f/showthread.php?t=676828)
Avayo 07-15-2020 11:35 AM
Scott's 92 S13
Hey guys! Always enjoyed reading other build threads so figured I would create one now that I'm making some progress on my 240. I actually ended up picking this car up back in 2017. I found it listed on Craigslist for a great price and drove down to Maryland with a couple buddies to pick it up. One of my friends thought I was crazy paying what I did for the car but I saw the parts that were included, and ended up making out like a bandit.
https://imagizer.imageshack.com/v2/1...922/Fa8LRx.jpg
https://imagizer.imageshack.com/v2/8...922/aueu88.png
While on the hunt for a 240 I really only wanted two things, no rust and a hatch. I didn't even mind starting with a shell, because I wanted to get my hands in there and make it my own. I was coming from a Subaru and while it's a great car, it isn't the platform I wanted to go all out on.
https://imagizer.imageshack.com/v2/1...923/6f8e74.jpg
FaLKoN240 07-15-2020 04:24 PM
This is approved for now. Update with some actual build thread progress or this will most likely be closed.
Avayo 07-15-2020 06:20 PM
First thing was first, I had to get that Silvia front end off. Before I even had the car I knew I wanted to run the kouki/type x aero on the car. I scored some parts from a forum member and it was a great start to the pop-up conversion.
https://imagizer.imageshack.com/v2/8...924/TSqzJW.jpg
https://imagizer.imageshack.com/v2/8...922/TThaAg.jpg
Next up was fixing the damage on the quarter panel. It was a pretty nasty dent but instead of slapping overs on it and calling it a day I had it repaired.
https://imagizer.imageshack.com/v2/8...923/10J0yg.jpg
https://imagizer.imageshack.com/v2/8...922/WpPNOq.jpg
After some going back and forth I decided to pull the SR outta there so I can paint the bay and patch up some holes. I have no intention on keeping this car blue so it had to happen eventually anyway. The battery tray was cut out pretty badly imo. Same deal on the other side. I had my buddy weld in some new metal so when I run the new intercooler piping it'll look nice and clean.
https://imagizer.imageshack.com/v2/8...922/RXmEGl.jpg
https://imagizer.imageshack.com/v2/8...924/NfAfTN.jpg
Just a little test fit with new fenders and bumper featuring my little man
https://imagizer.imageshack.com/v2/8...924/ft5Ufc.jpg
Avayo 07-16-2020 08:29 PM
My plans for this car are a full interior, fun street car that could also handle a track day here and there. I decided to ditch the sr and go for a jz. I ended up selling the turbo kit and engine for what I paid for the entire car! Headed down to Jersey to an engine importer and came home with this anchor.
https://imagizer.imageshack.com/v2/8...922/R4b7bM.jpg
I got the engine on the stand and started to tear it down. I replaced damn near everything maintenance related and tried cleanin it up best I could.
https://imagizer.imageshack.com/v2/8...922/kU17lv.jpg
https://imagizer.imageshack.com/v2/8...923/4lC7vI.png
Cams pulled to replace the valve stem seals
https://imagizer.imageshack.com/v2/8...924/kSkgaJ.jpg
https://imagizer.imageshack.com/v2/8...924/jXqmJ7.jpg
Prepped for paint
https://imagizer.imageshack.com/v2/8...924/6DYQ1Q.jpg
https://imagizer.imageshack.com/v2/8...922/hXQA2b.jpg
https://imagizer.imageshack.com/v2/8...923/FsPD16.jpg
Powder coated upper oil pan
https://imagizer.imageshack.com/v2/8...922/fbEOGh.jpg
New oil pick up tube and lower oil pan
https://imagizer.imageshack.com/v2/8...924/zeGmdP.jpg
Real Street billet timing tensioner bracket vs stock cast bracket prone to breaking
https://imagizer.imageshack.com/v2/8...922/H3jDV2.jpg
New water/oil pump, re-built and cerakoted cam gears
https://imagizer.imageshack.com/v2/8...924/CBPLwF.jpg
Powder coated valve covers to match the catch can
https://imagizer.imageshack.com/v2/8...923/JUVJsN.jpg
https://imagizer.imageshack.com/v2/8...923/Yfvqdb.jpg
Radium press in AN fittings
https://imagizer.imageshack.com/v2/8...923/DWiwnJ.jpg
https://imagizer.imageshack.com/v2/8...924/Ttm2Wm.jpg
https://imagizer.imageshack.com/v2/8...923/O7IetE.jpg
Avayo 07-17-2020 07:08 AM
Decided on running a tucked radiator instead of notching the support. Had to do a little cutting for clearance but welded in some new plates to cap it off.
https://imagizer.imageshack.com/v2/8...922/ykLZsl.jpg
https://imagizer.imageshack.com/v2/8...922/6RwTJr.jpg
https://imagizer.imageshack.com/v2/8...924/7fgJqU.jpg
Touge Factory catch can looking right at home in the corner
https://imagizer.imageshack.com/v2/8...923/1pTAft.jpg
Would've loved running a v160 but the prices on those things are hard to wrap my head around. So I went with the cd paired with the serialnine conversion kit. I've heard great things about this kit so hopefully does the job. Also went with some Freed engineering/Cusco mount kit to swap it in.
https://imagizer.imageshack.com/v2/8...922/BH5mrM.jpg
Avayo 07-17-2020 08:19 AM
Picked up a set of Z32 aluminum calipers and e-brake assembly. I was going to just rattle can them a gloss black but decided against that and had them sent off to be powder coated. I'm really glad I did because they came out awesome.
https://imagizer.imageshack.com/v2/8...924/ovkJwT.jpg
https://imagizer.imageshack.com/v2/8...922/4K2kzc.jpg
Couldn't help myself and pulled out a wheel to see what they would look like. Going to be running 17x9 +22 square set up on this car.
https://imagizer.imageshack.com/v2/8...924/hVhAdW.jpg
https://imagizer.imageshack.com/v2/8...923/KnGOBz.jpg
JIMB0 07-17-2020 09:21 AM
cant beat Kouki and TE's!
S14rebuild 07-17-2020 09:35 AM
Wow, great parts on an exciting build
Avayo 07-18-2020 04:42 PM
Agreed! Timeless combo. Looking forward to seein yours back from paint
Thank you man! Got a long road ahead but should be pretty awesome once its done
da_crew10 07-20-2020 12:50 PM
Now this is nice.
Avayo 07-21-2020 12:51 PM
Originally Posted by da_crew10 (Post 6388682)
Now this is nice.
Thanks bro! I'm trying the "do it right the first time method" lol
Like I said before, interior will be left in tact. Picked up some zeta 3's even though I kind've wish I just went with some oem 180sx seats.
https://imagizer.imageshack.com/v2/8...922/Qf4l6A.jpg
https://imagizer.imageshack.com/v2/8...924/TzBKMX.jpg
Obviously need a Nardi classic to continue that cookie cutter theme
https://imagizer.imageshack.com/v2/8...922/QZidWb.jpg
And a cross bar for the extra scene points...But seriously hoping this adds some rigidity to the car since I'm not running some fancy cage
https://imagizer.imageshack.com/v2/8...924/s5cVGx.jpg
Avayo 07-21-2020 01:57 PM
Since the car came with the Silvia front I had to pick up some pop up headlights. I got a set for cheap but of course they're old and seen better days so I sourced some new hardware. Kind've crazy you can still get new parts for this car, thanks to the boys at nissanparts.
New vs old
https://imagizer.imageshack.com/v2/8...924/bsUhrV.jpg
https://imagizer.imageshack.com/v2/8...924/KzrgCu.jpg
https://imagizer.imageshack.com/v2/8...922/LfYeQx.jpg
https://imagizer.imageshack.com/v2/8...922/THakcq.jpg
Avayo 09-21-2020 01:25 PM
Came so close to giving up on this car and parting it out for something else but decided I should just stick with it. Luckily I've got some good friends that talked me out of it. Plan is to place the engine in there next so I can see how much room I need to make for the CD.
Also sourced the rest of the exterior bits for the car.
https://imagizer.imageshack.com/v2/8...924/S5E0xc.jpg
https://imagizer.imageshack.com/v2/8...923/qV6IFE.jpg
https://imagizer.imageshack.com/v2/8...923/aemq1f.jpg
https://imagizer.imageshack.com/v2/8...922/uwRDe9.jpg
Fuglychuki91 09-22-2020 03:16 AM
Nice update man!
da_crew10 09-24-2020 10:04 AM
Originally Posted by avayo (Post 6388786)
cookie cutter theme
paint it red
Avayo 09-25-2020 04:54 PM
Originally Posted by Fuglychuki91 (Post 6395383)
Nice update man!
Thanks man, hopefully more to come soon
Originally Posted by da_crew10 (Post 6395654)
paint it red
I know right, it?s on my list lol Been done so many times but it?s so damn good.
Avayo 10-22-2020 12:52 PM
Had some time today to finally drop the engine in for a test fit. Now I can get a better idea on where I need to clear the trans tunnel. Overall super happy with how it sits in there. Dying to order more parts and get it going. Debating on selling the Subaru to fund this car. It would really help push it over the finish line.
https://imagizer.imageshack.com/v2/6...922/Cdrtdc.jpg
https://imagizer.imageshack.com/v2/6...924/b3xwZW.jpg
Avayo 01-03-2021 07:56 AM
Little end of the year update. Decided to list up the sti for sale a few weeks ago to free up some space/money for the 240. Luckily lined up a buyer in the first 24 hours it was listed and got my full asking price.
https://imagizer.imageshack.com/v2/6...922/w9DKp2.jpg
I started looking around for someone willing to tackle the paint and body work on the 240. I was kind've surprised a couple shops I talked to weren't interested in any restoration work. I guess it worked out because while waiting to hear back from a few different options I spotted a MK4 Supra for sale.
https://imagizer.imageshack.com/v2/6...922/Ni1vPY.jpg
I've wanted one of these cars for roughly 6 years now. Right around the same time the price on them skyrocketed. I was getting married, having a couple kids so it just didn't work out for me then. Then I saw this one owner, all original car pop up and knew it was now or never. It's a usdm n/a auto car with only 51k miles. I still can't believe I was able to find one un molested and not missing anything. The car feels like an absolute time capsule.
https://imagizer.imageshack.com/v2/6...923/WmiePm.jpg
It needs a little paintless dent removal and a good detail but overall for its age it's in excellent condition. For now I'm just going to enjoy it as is while I acquire the parts I want for it. Will be pretty basic, 97-98 headlights/taillights, front lip yada yada. And then eventually GTE/6 speed swap.
For now the 240 will go on the back burner unfortunately. But I still would like to keep it for my son or daughter. Hoping at least one of them will be a car nut like me.
Happy New Year guys!
Reece 01-04-2021 05:29 PM
in for supra posting
-kenny- 01-04-2021 09:44 PM
Wow this is gonna be a nice build.
Bonus point for Supra
S13project 01-05-2021 01:02 AM
Digging the attention tho the little things. In for more
Avayo 01-05-2021 02:53 PM
Appreciate the kind words fellas. Hopefully more to come soon!
k00laid83 01-06-2021 09:15 AM
I want a Supra so bad. That's one of my dream cars as well. Great Find!
da_crew10 01-06-2021 09:24 AM
In b4 partout!
Avayo 04-05-2021 07:44 PM
I don't have too much to update but I did finally get my turbo kit which was a big hurdle. There's so many options out there it took awhile to decide on what would suit my needs the best. I ended up with a g30-900 with a turbo smart 50 mill waste gate.
https://imagizer.imageshack.com/v2/6...923/gukXYy.jpg
https://imagizer.imageshack.com/v2/6...923/K4mWoV.jpg
https://imagizer.imageshack.com/v2/6...922/BF7dL6.jpg
Also the parts pile for the supra is starting to add up. As of now my plans are to continue the 240 build with my vvti engine and CD trans. The supra came from the factory with a TT auto diff (A02D for my supra guys) which is a 3.7 LSD. Turns out that pairs pretty well with the Grannas T56 kit. So at some point I'll use that for my trans and then build the GE with a GTE head, PHR turbo kit yada yada. That'll be a project for the future because to be honest, it's just not in my budget right now.
But I did want to start sourcing parts while I can get them bnib
https://imagizer.imageshack.com/v2/6...924/3XXKD1.jpg
https://imagizer.imageshack.com/v2/6...924/3owM8v.jpg
https://imagizer.imageshack.com/v2/6...924/oz7yaT.jpg
https://imagizer.imageshack.com/v2/6...923/GVKNeF.jpg
Then there's this goofy ass Camry wheel the 93-97 has for god knows what reason
https://imagizer.imageshack.com/v2/6...923/SSEger.jpg
So I sourced a nice three spoke for it
https://imagizer.imageshack.com/v2/6...923/Gxftmr.jpg
That's really it for now. Next up for the 240 are clutch and injectors, then ill be able to get the engine and trans in for my buddy to work his magic on the welder.
PoorMans180SX 04-07-2021 08:33 AM
Great looking stuff you have going here man. I like the idea of notching the lower rad support like that.
hiimelvin 04-07-2021 10:11 AM
Beautiful builds so far. Great attention to detail and really tasteful mods. Good call on that Supra steering wheel.
Avayo 04-07-2021 12:22 PM
Thank you man, I appreciate that. Yeah I kind?ve figured if I had to cut and remove anything I?d add some back. Plus looks a little cleaner once it?s painted
Thank you man! Yeah that old wheel is terrible, I don?t know what they were thinking haha
