No start after new fuel pump?
Alright, so after having my fuel pump go bad about a week and a half ago, I finally had a buddy put in a p2m 340lph. The car started and seemed ok with no hiccups. After driving about 15 feet, it stalled out and refuses to start since then.
Is it possible that I'm just not getting voltage to the fuel pump now? Sent from my iPhone using Tapatalk |
First step I would say it to check fuses and such. When you turn your ignition on(without cranking the engine) can you hear the fuel pump prime?
Fuel lines backwards...
Changed out the fuses, started and ran for 30 seconds before going out again. Would this still be a symptom of fuel lines being backwards, or does it seem that I'm now dealing with a short.. Perhaps bad relay ?
just take out the hose going to the rail turn the key on, and see if gas comes out,
jeez all you have to do is take off 1 hose clamp that do alot of diagnosing |
Does your car have gas in it? Also could just pull off the fuel feed line as stated above...
1 Attachment(s)
There's gas in the car. Lines are fine. Changed out fuses again, got it to run for 15 minutes before it not starting again. Did find this though Attachment 87915 wire broken off.. Could this be the source of the problem?
Omg bro. Why not just reattach the damn thing and find out?!?!?!?!
Yeah I mean it's broken and I'm stranded bro. If only I could materialize something to solder it Sent from my iPhone using Tapatalk |
Set something on top of it to hold it making contact Or sit around playing on your phone. |
It's taped. Still no luck. Hopefully my phone doesn't die too Sent from my iPhone using Tapatalk |
If it keeps popping fuses you have a short to ground somewhere in the circuit. The wire hanging off is an obvious place to start.
Yeah, that's what I was figuring. Problem is now, the pump isnt priming at all. Either that wire, which I tried taping and rigging with no success.. Or I'm stumped at this point Sent from my iPhone using Tapatalk |
So with the wire rigged up the pump won't turn on at all? Did the wire break when installing the pump or was it like that as soon as you took the cover off ? It's possible it not a short and your pump is pulling too much power and overloading the circuit
Correct. I had a friend install the pump while I was at work (working 60+ hours ) , so I can't confirm. If indeed the pump is overloading the circuit , how would I remedy this? I'm going to attempt another ECU as well . Sent from my iPhone using Tapatalk |
if the pump is overloading the circuit the pump is no good. wouldnt be the first new pump that didnt work. unfortunately based on what youre telling me getting this figured out is going to be above your skill level. my advice is to fix that wire and see if that works. if that doesnt fix it you need to take it to a shop and have someone trouble shoot it. It would be cheaper than throwing parts at it
Gotcha. I replaced the Isis 255 that the previous owner had installed with a p2m 340. I'm starting to think now that the pump wasn't the issue from jump. Anyhow, Taking it in was my next course of action . Appreciate the help Sent from my iPhone using Tapatalk |
May be just that wire. Do that first
After taping it, no luck.
It's a ground wire from what it looks like. You can't just tape it to that dirty ass connection.
Well I'm by no means versed in anything electrical . Perhaps soldering the connection will cure my woes. I'll give it a shot tomorrow if I can. Appreciate it guys Sent from my iPhone using Tapatalk |
It still needs to be scrubbed clean.
You will wind up melting what's on the other side from the iron before you get a good solder on there. |
Word. Gonna hit Google and see what all is necessary. I hope this is it Sent from my iPhone using Tapatalk |
Try bench testing the pump.
Remove from the fuel tank, and test it with a 12v battery |
Has the pump been run dry? Can easily fry the bearings making them useless.
Theres a relay for the pump, check that. Also check the ECCS relays as they control the pump functions. |
Nope, car had gas in it. The relay was tested and working fine, same as ECCS relays . Haven't had time to fix that wire yet, but hoping that's it Sent from my iPhone using Tapatalk |
You could have other damaged ones too that arent dangling loose.
Any luck? Might have to break out the multimeter. Jdm Legion has good diagrams if you end up needing them. Check the wires on the pump for proper function, and although it may sound stupid, make sure you have it wired correctly. My Gtr pump fit in fine but there were some loose wires left, as those pumps adjust their duty cycle in a gtr according to how much fuel they need to pump. In an S chassis it is running hard no matter what.
Thanks sills. I'll have to check it out when I get some time off work later this week. I conveniently had an appointment at TF works, so hopefully it'll be like having a whole new car in the next week or so. Sent from my iPhone using Tapatalk |
| All times are GMT -6. The time now is 04:36 AM. |
