-   Tech Talk (#/f/forumdisplay.php?f=8)
-   -   Hoosier Tire Sizing: What fits, and what doesn't (Finally stepping up) (#/f/showthread.php?t=210385)
codyace 08-26-2008 03:10 PM
I'm tired of wasting street tires on the track, and finally with my job am able to step up to a decent tire.
However, my issue now goes into sizing and what is to small/to big.
I'm looking at either running a 225/45/17 Hoosier all around, or a 245/45/17 all around. The reason I say all around, is that I'd like to be able to rotate them all around instead of just side to side (although I'm not sure that's even a good idea).
I currently run 225/45/18 in the front and 245/45/18 in rear of my car (on 350z track wheels) and have no fitment issues, even with 10mm spacers up front.
However, knowing track tires, I know these will be slightly taller. I know the rear will fit, but am concerned with the front. I plan on running these on late model Mustang GT wheels.
So here are some dimensions:
Ventus RS-2: 225/40/18 Section Width 9.1 Tread Width 8.0 Diameter 25.1
Hoosier: 225/45/17 Section Width 9.6 Tread Width 8.7 Diamter 24.5
245/45/17 Section Width 9.9 Tread Width 9.4 Diamter 25.3
I'll hafta go home and do some measuring, but am just wondering if 225 wide tires will be enough for a HPDE only car, or if going 245 would be the better idea? The tires on the car now (in their sizes) work great IMO for a true street non r compound tire.
Any help is appreciated (Unsure if this is in the right section either, seems to fit a few different ones)
-Cody Ace
McRussellPants 08-26-2008 03:13 PM
245/40/17 or 255/40/17 is a good tire size.
its fun enough, and you won't have any issues fitting it.
all the tires you listed are really tall
McCoy 08-26-2008 04:33 PM
A 255/40 is as small as I'd go, Cody. If you find that you still have some room, then maybe step up to a 275/40/17... for the price you can't go wrong.
Also, go with an RA-1/NT01 over the hooiser, you'll get alot more useful life out of them without worry of flat spotting or wearing them out in 4-6 track days. I've gone through 4-5 sets of hooisers and am now on RA-1's, and will probably stick with them from now on.
racepar1 08-26-2008 04:39 PM
245's nothing less. If need be pull the fenders. I would agree on switching to another tire because of the short life span of the hoosiers, but the grip of the hoosiers will be addicting.
KwKouki 08-26-2008 07:00 PM
ever look into victoracers? been seeing lower numbers from those than the hoosiers lately.
