The low-down on S13 Diff options?
So, I'm looking at diff options for the S13. I see that the J30 and N/A 300zx diff's won't directly bolt-up to the S13's frame. I read something about the S13 doesn't use bushings in a few spots, and requires a different cover to get the newer style diff to fit.
What I need to know, is will the newer style (J30,300zx N/A) R200 diff fit in the S13 non-lsd case? That way, I could just swap it in, and use my old case. I'm assuming that you would still need the S13 LSD halfshafts... but I can get those easily. Travis |
lsd
here is a list of options for you.
89-94 OEM VLSD 95-98 VLSD (with S13 diff cover swapped on) 90-96 NA Z32 VLSD (w/ pre 95 J30 axles or 180sx axles) 95+ J30 VLSD (with S13 Diff cover) Pre 95 J30 VLSD (w/ 95+ J30 axles OR 180sx axles) 180sx VLSD with its own axles or pre 95 J30 axles |
Yeah.. no need to swap internals.. just replace the diff cover. and use the appropriate axles with the correct flange (5-bolt or 6-bolt.)
Also, Any r200 diff will swap into an s13 housing. This includes R32 skyline diffs, S15 helical diffs, Z32 NA diffs, J30 diffs.. anything with an r200. Just make sure you get the right output shafts and axles for the diff you use. |
Direct Fit: 91-93 240sx VLSD 89-90 JDM S13 VLSD 96-98 JDM S13 VLSD JDM S14 and S15 VLSD (with S13 diff cover swapped on) R33 Skyline (R34 as well?) VLSD (with S13 diff cover swapped on) 95-98 240sx VLSD (with S13 diff cover swapped on) 1/94+ J30 VLSD (with S13 Diff cover swapped on) Fit with pre-1/94 J30 axles OR JDM S13 axles OR R32 Skyline axles OR 6 bolt vlsd output flanges OR shaved open diff output flanges: 90-96 NA Z32 VLSD Pre 1/94 J30 VLSD 91 - 95 JDM S13 VLSD JDM R32, A31 and others Non VLSD oem options: Z31 Turbo (non SS model) clutch type +4/87: works with open diff output flanges. Use S13 case and cover R32 and R33 GT-R only, non V-Spec clutch type: uses 31mm 30 spline output shafts. 3 out of 6 bolts line up (sort of) when using skyline output shafts or R230v output shafts (Q45 and turbo Z32) S15 torsen, 6spd turbo only: use S15 output shafts, late S14 VLSD might work, R230v might work with 3 out of 6 bolts lining up. R34 torsen, GT-R non V-spec: unknown but I assume its 31mm 30 spline 350Z/G35 torsen: supposedly R205 according to NISMO japan website. Unknown fitment in a 240sx. I think thats pretty definitive :D Edited the s15 transmission listed. I'm sure it was a typo. |
I'm archiving this. Good work Duff!
Just weld it. Thats what i run... :naughty:
hmm
this forum isn't open to users.. shouldn't be anyway. I've gotta adjust permissions. this is where we archive threads that have good info. |
| All times are GMT -6. The time now is 01:39 AM. |
