-   Engine Tech (#/f/forumdisplay.php?f=96)
-   -   **HELP with finishing RB20 swap** (#/f/showthread.php?t=435702)
CantSTOP 02-14-2012 05:38 PM
Need help with finishing up my RB20 swap in my 89 Sohc.
http://i165.photobucket.com/albums/u...Tee26/fpr1.jpg
I believe 1 is the FPR vacuum? 2 is the aftermarket FPR? 3 is a line from the Fuel Rail?
If 2 is the FPR where do I hook up the line for the FPR vacuum 1? Which goes to the fuel return lines? And which goes to the fuel filter?
http://i165.photobucket.com/albums/u...Tee26/fpr3.jpg
http://i165.photobucket.com/albums/u...Tee26/fpr4.jpg
Here are different angles.
http://i165.photobucket.com/albums/u...Tee26/fpr2.jpg
This is on the firewall side of the number 3.
http://i165.photobucket.com/albums/u...0dashwires.jpg
Is this all the wires I need for the dash wiring? This is what came with my harness for the RB.
http://i165.photobucket.com/albums/u...cdashwires.jpg
This is from my 89 sohc Dash wires. Any of the other wires useful?
http://i165.photobucket.com/albums/u.../sohcplugs.jpg
And last my car was originally auto...Can I leave them like that or do they need to be plugged up atleast? I didn't do the reverse lights yet, plan to when I get the actual car running. Already did the start up/parked plug can't see it though.
Thanks for any help!
Jtuned_andy 02-14-2012 06:14 PM
#1 is a vacuum source for whatever, sure FPR go for it
#2 is just a fitting, you have no FPR on that rail. That fitting is used in conjunction with aftermarket regulator and or gauge
#3 is, or should be, the feed line for the fuel rail. You will run the fuel line from the fuel filter into this.
CantSTOP 02-14-2012 06:45 PM
Okay thanks, I get #3. How about the other fuel line? The lower one right next to the line that connects to the fuel filter. Where do I connect that?
And so I have no fpr? What should I do with #2?
CantSTOP 02-17-2012 06:27 PM
Gonna pick up a afpr.
Anyone know about the wires/plug?
