-   -   Boost and grind problems (#/f/showthread.php?t=280387)
Ambush 09-23-2009 12:59 AM
new to the forum btw.
i've been searching up for a while and couldn't really find the right answer so hopefully you guys can.
I got a Red top SR, with a T25, and a HKS Exhaust.
Boost Problem- it starts to choke when I floor it, and tends to backfire pretty loud ( light gray smoke comes out ) but I'm guessing its because its running really rich.
Grinding Problem- My gears tend to grind pretty badly sometimes when i mostly put it in first and reverse.
ex. I'd be on my drive way backing out, and when i put it in reverse you hear this grinding noise, and it continues on till i put it in neutral or another gear. This happens with 1st gear a lot also.
Thanks.
o1roadkingrider 09-23-2009 06:33 AM
Boost problem?
Could be a camshaft or other valve timing component wear. Is the smoke really gray, or is it kinda blue? Could be oil fouling of your plugs if its blue. A fouled plug would cause unburnt fuel in your exhaust, which is ignited by the next properly firing cylinder to create the "pretty loud" backfire.
Check your spark plugs and see how they look. Also, a compression check and vacuum reading would help determine if the engine is working properly before blaming it on a boost issue.
That's my .02 anyway.
JJ
Ambush 09-24-2009 11:46 PM
JJ
thanks.
I'm going to need a turbo rebuild.
