ProjectGarage's Fuel rail questions, now in 1 thread...
I basicall need the exact opposite of this http://www.enjukuracing.com/images/fpradapter.jpg
Does that even exist or am i going to have to start making them? I want to run my stock fpr on an aftermarket high flow fuel rail such as the Yamato Garage or the Circuit sports unit. |
Hahaha, nice.
No, you don't want to run your stock FPR. It sucks even at OEM flow levels, much less a high flow fuel pump/rail combo. If you're baller enough for a -6an fuel rail, you should protect your investment/sanity and get a reputable FPR. Aeromotive is good, Sard is good, Nismo is generally not the best, FuelLab is new but has gotten great reviews. Real FPRs start at ~$100. |
I use -6 line w/ a JGY fuel rail. Looks good and does a great job. If i were you i would get a good FPR. I had a SARD that broke on me so i just went with a Aeromotive one, if you going to do it, do it right and do it all. While your at it BigEnd makes a -6 AN billet fuel filter to that looks good with the setup and flows good. I love it.
The best value I found is a Fram HPG-1. It's a paper replaceable element, screens to 10 microns, and has a very low pressure drop - all for ~$50. Pegasus - Fram HPG-1 Hi Performance Gas Filter http://www.pegasusautoracing.com/Images/M/1122.JPG |
Im going to be keeping the boost stock. I need a new rail and would like to replace the FPR as well. Im already getting new stock size injectors. I wouldnt mind running a high flow rail and probably a tomei FPR, the only thing im worried about is can i make it run like stock with these two parts. Or should i just get a new OEM rail and FPR?
Installing a high flow fuel rail and aftermarket fpr (SR related)
Im going to be replacing my Injectors, Fuel rail and Fuel pressure regulator.
Ill be using this fuel rail http://www.frsport.com/images/detail...S13-WSK_03.jpg With Deatschwerks 370cc injectors (stock size) And also ill be using a Tomei FPR http://www.frsport.com/images/detail...1_05_15259.jpg So from my understanding if i adjust the Fuel pressure to 43.5 psi (without the vacuum line plugged into the fpr) it should run like stock? Even with the high flow rail? Im not doing anything high hp and im running stock boost, I need to replace my fuel rail and figure id rather get this sexy one than another stock one. So will it run richer because of the rail or does the rail not matter and its all based on injector size/fuel pressure? |
If you set it for 43psi, it will run like stock.
Like I said in your other thread, you should just stick to stock and save the $hundreds. |
lol what in the hell for if you're not upgrading everything else. And don't use douche works injectors.
i need new injectors deatschewerks are the best for their money unless you know of another company that sells 370s for the same pricing. The reason im replacing all this stuff is because i need a new fuel rail a new fpr and new injectors so i figure why not buy baller parts in that field like i have with everything else so far.
370's? just get oem sr20 injectors. oem is better than anything out there ad cheaper too. You can get a set for about 100 dollars.
i know you made 2 threads for this basically. you don't need a fpr fitting for that fuel rail. that's the circuit sports rail right...? it already comes with all the fittings you need. they even show them in the other frsport pics where you obviously linked it from!
I basically want to run the circuit sports rail without the -6an lines since it comes with the regular fittings too. What i was wondering is if there was a way to hook up the stock FPR to that rail or if i can use an aftermarket FPR but still have it run like stock just have baller ass quality parts on it.
By this if you mean that you just want to throw your money down the toilet with no difference whatsoever go right ahead.... OEM nissan parts are "good quality parts." |
^thank you.
Stock FPR's are not baller. Neither are stock sidefeeds, AN lines or CS rails. |
amen brother!
Yeah nissan parts are definitely great quality. I would use a brand new stock rail and brand new stock fpr if i it didnt take months to get the fpr. I just want to know that the parts are going to last. Are Deatschwerks really not good injectors? Ive heard alot of good reviews on their stuff. |
I agree, Im not trying to be baller with stock parts lol im trying to get "baller quality" parts which i know circuit sports is not which is why i may go with the Yamato one instead. Anyways I keep hearing more and more people talk shit about Deatschwerks injectors.. Whats the deal with that?
Sard** Nuff said
your engine has had those parts since it came out of the dealer and were still working until recently (i guess, if your changing them) i think that proves the lasting time of a oem part... |
Yeah sard is good i know that tomei is as well ill be using the tomei fpr for my setup
Ive heard good things about the tomei fpr
id rather get DW injectors than RC crap
I keep hearing that z32 injectors are the same?? Im wondering if i can just buy them from a local parts store or what i should do? Its looking like im getting either DW or idk yet haha.
sr20 and z32 are both 370cc injectors.
Again, buy a set of injectors off the for sale section for $100 and call it a day. |
Anyone using Deatschwerks injectors?
I need to get some 370cc injectors for my SR i want to buy them brand new but the actual SR injectors from nissan take about 3 months to get. So the only 370 replacements ive found are the DW ones. I need some feedback before buying them.
Thanks |
Seriously?
Tons of people use them. Tons. |
| All times are GMT -6. The time now is 05:42 AM. |
