87 Nissan 200SX s12 s14 SR20DET build!
Hello my name is Christian I've been on Zilvia for awhile now and I've owned about 14 different s13s, s14s.
They are awesome cars however I wanted to build something a little different so I purchased this s12 off a guy in Long Beach for cheap back in August of 2019. It took me a full year to get it to where it is now, when I bought the car it came with full s13 front suspension stance coilovers, pbm arms rear s13 subframe conversion which not a lot of s12 guys do cuz its pretty hard tomei 2 way diff fully adjustable arms in the rear with Porsche shocks and z32 aluminum uprights this is how it looked when I had the car picked up(not me in photo lol): https://i.imgur.com/byssXQ1h.jpg this one is a little rarer because it came with a vg30e but the car wasn't running and I had my mind set on swapping a sr in it so out goes the vg:sadwavey: https://i.imgur.com/ehKcJcqh.jpg Once I had the motor pulled it was time to prep the engine bay for paint. this isn't a show car so I just rattle canned it black came out ok. https://i.imgur.com/NuUuf3Wh.jpg https://i.imgur.com/jcbQthJh.jpg https://i.imgur.com/neB7Gamh.jpg https://i.imgur.com/CRfAS2Hh.jpg Also before I painted the bay I made holes for the IC piping they're not perfect, I also added rubber grommet https://i.imgur.com/whTDZ5Hh.jpg the rear hatch glass was shattered and trying to find parts like that for these cars is a bitch! its not like 240sx where there's plenty of parts luckily I found a guy in Oakland so I drove 5 hours to pick it up and this is how we strapped it to my friends Yaris lol https://i.imgur.com/4RJaLcsh.jpg Installed https://i.imgur.com/DU5qwA9h.jpg My rack&pinion was leaking so I got a new reman one from vatozone I also installed new bushings but didn't snap pics of that https://i.imgur.com/lhum5d2h.jpg https://i.imgur.com/DXxatBYh.jpg Alright so this is how I bought the motorset. the bottom end was already assembled and was bored .020 over has Wiseco 86.25mm pistons ACL race bearings Eagle H beam connecting rods head is stock, had oem turbo the motor was missing a few things I had to piece together but got everything for $1200 which I thought was a really good deal! https://i.imgur.com/IlCTPL8h.jpg Tomei head gasket I also used ARP head studs. https://i.imgur.com/iH1L1eSh.jpg the head was hot tanked and decked. and tested fresh from the machine shop :hsdance: https://i.imgur.com/OjDfobUh.jpg https://i.imgur.com/fE3sX2Sh.jpg getting there haha I also had the valve cover powdercoated https://i.imgur.com/eQPtL5gh.jpg ACT lightweight flywheel and exedy clutch https://i.imgur.com/sGiGBHVh.jpg https://i.imgur.com/FJhg06Fh.jpg https://i.imgur.com/Z8utb9Oh.jpg transmission is mounted! https://i.imgur.com/fv6fLEVh.jpg putting the motor in for test fit. the sr bolts right into the s12 but since the car had a vg30 they sit higher so that's why I got bmw motor mounts to lower it. oh and I did all this by myself in my garage!! https://i.imgur.com/FJYo9H0h.jpg https://i.imgur.com/NMtJoKdh.jpg trying to figure out the intercooler piping. CX racing FMIC for s14 sr20det https://i.imgur.com/Sk5p8uSh.jpg https://i.imgur.com/xrQT9E0h.jpg https://i.imgur.com/ebvWFUeh.jpg I cutoff the recirc pipe and had the BOV flange welded in along with the IAT sensor https://i.imgur.com/MtDpA6bh.jpg I'm surprised I got the FMIC to work with the s12 lol https://i.imgur.com/XU3nM3Dh.jpg trying to figure out how the radiator was going to sit https://i.imgur.com/JhICkwAh.jpg had to cut some of the bracing on the hood https://i.imgur.com/Mvya6kxh.jpg bought a Tomei cover and drive belts https://i.imgur.com/j1SQrlQh.jpg bought a timing chain tensioner from MAZWORX such a nice piece https://i.imgur.com/YEuISVDh.jpg https://i.imgur.com/Ff7VH4gh.jpg circuit sports 3 inch turbo elbow https://i.imgur.com/uTIjGrAh.jpg tomei 87.1mm headgasket https://i.imgur.com/nFKKcfDh.jpg Probably the best purchase I've made for the car is this wiring specialties universal standalone engine harness https://i.imgur.com/x9Jl8jrh.jpg Tomei Expreme turbo manifold https://i.imgur.com/6oHVFW4h.jpg https://i.imgur.com/EudPVHDh.jpg new oem oil return hose and bmw motor mounts lol https://i.imgur.com/blsjipqh.jpg https://i.imgur.com/JPRs4PVh.jpg 750cc five o injectors https://i.imgur.com/RfJQRP2h.jpg Garret GT2871r brand spankin new lol https://i.imgur.com/N3UiLpjh.jpg oh yeah https://i.imgur.com/ORMh9o4h.jpg swapping a couple things over to the new turbo, I did run the oem one for a bit but had to upgrade https://i.imgur.com/FlNnAEqh.jpg https://i.imgur.com/gFBa7woh.jpg https://i.imgur.com/mlRWpeTh.jpg the water pump was leaking so I replaced with a new oem one! this is a must buy forsure https://i.imgur.com/JkUtqtFh.jpg https://i.imgur.com/SwikbrZh.jpg |
Alright now that most of the motor is done, I swapped out the fuel pump for a walbro 255 :D
https://i.imgur.com/t5uSl7zh.jpg old left vs new right https://i.imgur.com/CZPFL65h.jpg https://i.imgur.com/RAd6Oxwh.jpg then I installed a tomei 2 way that I got with the car https://i.imgur.com/SPoGD8Ih.jpg relocated battery https://i.imgur.com/aBFEcPLh.jpg putting the motor back in late at night https://i.imgur.com/vHflXrDh.jpg https://i.imgur.com/klgEyNTh.jpg its in! lol https://i.imgur.com/dkIBVqTh.jpg https://i.imgur.com/Ia4tZgPh.jpg https://i.imgur.com/IxoRoz0h.jpg had a extra pipe for the air filter https://i.imgur.com/chbQtfxh.jpg bought a GK tech clear CAS cover https://i.imgur.com/Gmk4Keth.jpg all buttoned up https://i.imgur.com/G93OYXYh.jpg |
Nice work. Cool project!
Great parts, excited to see an S12 done right for once.
Question, do you know if all ACT flywheels aren't proprietary? What model is yours, and are you sure an Exedy clutch is compatible? Thanks! |
You have an interesting build out there. It seems like this car will keep you busy. Good luck and have fun modifying this car.
| All times are GMT -6. The time now is 08:41 PM. |
