S14 SR20det ECU WC wiring
2 Attachment(s)
Hey everyone I'm having to wire my own MAF plug, just the stock one because somehow my harness didn't have it. I'll attach below an image of the pin out but I am unsure if I did it correct so if someone could advise. I used pin 26, and 27. I tried tapping the 12 volt into the ecu relay (pin 16) since it pushes 12 volts but now my car won't start only cranks. However it could be unrelated.
Attachment 86800 Attachment 86814 Sent from my iPhone using Tapatalk WAS UNRELATED, SPARK PLUGS HAD JUST HAPPENED TO GO OUT!! |
| All times are GMT -6. The time now is 08:21 PM. |
