-   -   okay....wtf is up with my suspension (#/f/showthread.php?t=559091)
akaina240 03-21-2014 12:14 PM
First I know my car needs rack+pinion/steering rack replaced ASAP.
I recently got new tires installed, hasn't been aligned(cuz im waiting to fix rack+pinion/steering rack)
I know my car is set up for a harsh ride, but it has never this been harsh/annoying.
DMAX Coilovers
CUSCO RUCA
Powered by MAX toe rod
Powered by MAX Subframe Rizers
When I am driving on the freeway, my car is bumping up and down a lot as well as I feel like my car steers into every crack/crevice on the freeway.
My question is... is it just because I need to replace my rack+pinion/steering rack that's causing this??? Or wtf?
heychris 03-21-2014 02:17 PM
Maybe rack....but sounds like your toe or caster is out of alignment
Sent from my SM-N900V using Tapatalk
Tono 03-21-2014 02:19 PM
i had a similar problem with my car. when i would drive in the highway going 60+ ish and let go of the gas, the rear end would swing out violently.
it turned out to be the front inner tie rods.
thats just the issue with my car. installed new ones. got alignment. its all gone.
