SR20DE AC compressor rebuild info
I have a 92 S13 Silvia Q with a SR20DE, when I hit the AC button the fuse for the power mirrors blows, from reading I think its a seized compressor (verifying today) I just had my AC converted to R134a and id rather not drain it if I can.
I have been told then exist but can not find any AC clutch rebuild kits. Does anyone know if all Nissan or All SR20 compressors are the same? I can find AC compressors for FWD nissan and infiniti SR20s. Or do I just need to convert to a KA24 ac compressor with the adapter? finally I saw some people just rebuild by updating the shims / washers. does anyone have any hands on experience fixing the AC? Thanks |
Going to a KA24 compressor, even with CodyAce or other adapter kit could be problematic due to JDM lines and RHD. Maybe try searching for a direct replacement (i.e. 180SX, 200SX etc).
going to be using a bracket from https://www.240sxmotoring.com/ka24de...n-bracket-kit/ |
Cool and good luck- if you get it sorted, Please post a pic or two of your mod to the line- could be helpful to others.
| All times are GMT -6. The time now is 12:09 AM. |
