So you think you know engines eh?....
Alright, So here is the sitch, Its got me at my witt's end..
Lovely young lady buys a mint s13 hatch, 106xxx km, lady driven, one owner *grandma* auto.. By far one of the minty'st cars I have seen in ages.. We take it through emissions testing, and it fails horribly in the idle portion.. Readings are as follows: DRIVING HC Max:90.00 Vehicle 8.00 CO Max: .76 Vehicle: 0.00 NOx Max: 1117 Vehicle: 12.00 IDLE HC Max:108 Vehicle:276 CO: Max: .82 Vehicle: 4.43 So, With that information I decided to look at the coolant temp sensor as the culprate, Backed that up with a satanic code 13 off the ECU.. I replaced the sensor, Code was still apparent. I than tried another brand new sensor, Code still remained. So I checked continuity between the 3 ecu pins, and the 2 sensor pins and confirmed continuity.. Still the code was coming back. So I rewired the Blue/Orange I believe from the CTS-> pin 18(i believe), At wich point the CTS code dissappeared.. So I swapped the cat for a brand new one I had laying around along with a brand new 02 sensor. Car failed again same readings same situation.. CTS code came back.. At this point I than played peek-aboo with code 13 for a couple days.. I have now ran the ground wire for the CTS straight to the block wich seems to have delt with that issue, For the time being.. I am now showing Code 55. Although with code 55 being shown, the afr's measured at the tail pipe via an AEM UEGO at idle are still 12.2-13.6.. Timing is set to 15* CTS Resistance is correct Maf Voltage at idle is 1.44 Fuel pressure vac disconnected is ~40psi Tps is set to .45 What am I missing that would cause the idle circut to be pig rich as it is.. I think this is something stupid and small, that I am just not thinking of.. I feel like I have tried everything at this point.. The car runs like a swiss watch, doesnt miss a beat.. But is stupid rich.. Things I think are possible at this point.. Leaky injector Exhaust leak at manifold giving o2 sensor a false lean. Discuss please! |
Could it be the ecu? Mine wouldn't pass smog so my neighbor gave me his bad bam! It worked
What condition is the CAT in? A lot of times they are blown out or jacked up even after 100K miles on USDM KA 240s...
I'm gonna go with the leaky injector.
lol, air fuel is adjusted in closed-loop by the narrowband oxygen sensor. Install a narrowband oxygen sensor and let the ECU do it's job.
Or, plan B is use the analog output from the AEM to simulate a narrowband. Either way, the ECU is capable of using that 0-1V input to modify injector pulse width. |
As previously mentioned I would look into the catalytic converter being bad or clogged. replace the oxygen sensor and make sure its functioning properly if that is bad its giving a false code the ecu.
| All times are GMT -6. The time now is 04:16 AM. |
